Show only
Search instead for
I have a road corridor with a 4:1 slope cut and fill to the existing surface. The corridor only shows up one side. I couldn't figure out the reason and fix it. I need your help. Thank you
It seems like you have not set existing surface targets at one side of the road. May be you have two corridor regions and in one region all existing surface targets are not set properly.
