river and flood analysis
Message 1 of 10
I downloaded the river and flood analysis add on for Civil 3d and it did not show up in the tool bar. Where do I find it to add it to my tool bar?
Replies (9)
Message 2 of 10
BrianHailey
Toolbar? Or do you mean ribbon?
It won't show up in your toolbars. If you've turned your ribbon off, you'll need to turn it back on to see the tools. At the command line, simply type RIBBON.
If you were referring to your ribbon, change your workspace to something else (such as "Drafting & Annotation") and then back to "Civil 3D". If that doesn't work, let us know.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 10
AlmasSuljevic
Autodesk Support
Autodesk Support
If you installed it and the River ribbon is missing from your screen (check if it was all the way to teh righ by expanding) then it may mean that the ribbon was not sucessfully loaded. Please try following procedure and let me know if it loads tools and if the tools remain loaded after you restart the application.
  1. In command line type CUILOAD to get into Load/Unload dialog
  2. If you don't see RIVER there it means it's not loaded
  3. Click on Browse button and browse to C:\Program Files\Autodesk\Autodesk RFA 2015 or version you have
  4. Select River.cuix and click Open
  5. Back to Load/Unload Customization click on Load button and OK
  6. This should load the tools
Also, run WSSETTINGS command and then click “Automatically save workspace changes”. This will “remember” your changes.
I hope this helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 4 of 10
BrianHailey
Personally, I'm not a big fan of doing this. There's not really anything wrong with it, I just prefer the other option. If I make a change to my workspace and I don't like it, all I have to do is change my workspace, change back to the original, and I'm back the way it was. If I make a change and I like it, I'll change the WSSETTINGS to automatically change, switch workspaces (workspace is now saved), switch back, and then change WSSETTINGS back to not automatically save.
Most people I've talked with, however, prefer the way Almas suggests.
GEI Consultants
My Civil 3D Blog
Message 5 of 10
Pointdump
Almas,
I lost my RFA Ribbon Tab and can't get it back. I tried re-installing RFA, but it says it's already installed. Following your steps, you lose me at 4. I can't find River.cuix.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 6 of 10
Pointdump
Almas,
Never mind. I scoured my hard drive and found it. Installer stuck it here:
After CuiLoad, all is well. Thank you.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 10
leonid_d
@Anonymous with "menuload" command you can find the folder where the file containing the menu for the river
Leonidas Dávila
Ingeniero en Diseño
Hidráulico - Sanitario
Message 8 of 10
Matt.Anderson
I usually just type RMSABOUT or RMSHELP and the arx should load the CUIx.  Be careful - I keep forgetting - one will crash the application - the other works.  I typically guess wrong on the first try.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 9 of 10
BlueOak_IT
Observer
Observer
I downloaded river flood plugin for Hamed and i dont see it in the ribbon. I tried changing Drafting and annotation to civil 3d and back to Drafting and annotation no success. We also tried Planning and analysis and still cannot find it. I show its installed when i try to reinstall it. Ive gone into my C:\Program Files\Autodesk\Autodesk RFA 2016 and do not see river.cuix; However, we do see riverfloodplain.arx. Please help.
Eddie and Hamed.
Message 10 of 10
leonid_d
Leonidas Dávila
Ingeniero en Diseño
