River & Flood HEC RAS Module 2018
swatfor_PDCOG
Message 1 of 1
swatfor_PDCOG
After entering all relevant information into the River and Flood 2018 module, and checking the section views  and "computing analysis", everything appears fine.  However, adding after section results, the section views actually grow taller every time I look at the section description.   Even it I enter the appropriate starting elevation and axis height, the view continues to grow.  What am I missing?
If I erase the section results, the view begins to act normally again and will respond to changes in the axis height and elevation as it should.
I have included screenshots and error message.
Thanks for your help,
Sandy W.
Sandy W.
Replies (0)
