Civil 3D Forum
rim to sump height
7 REPLIES 7
Message 1 of 8
1015 Views, 7 Replies
rim to sump height
I'm trying to determine why autocad is throwing a large number (jelevation) in the rim to sump height setting on Structure Settings. Autocad is recognizing the correct surface elevation but is jacking up my rim elevation to 180' +/- above the grade line in my profile.
It's not all structures along my alignment but maybe a third of the 40 manholes for the alignment have this issue. They were all placed at the same time using structure and pipe and going thru my alignment to add the structures and piping.
Thanks in advance!
Ed
rim to sump height
Thanks in advance!
Ed
7 REPLIES 7
Message 2 of 8
Jay_B
Jay_B
Can you post the dwg here?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
C3D 2018.1
C3D 2016 SP4
Message 3 of 8
Mike_Hurtado
Mike_Hurtado
Autodesk Support
Autodesk Support
As mentioned, a drawing would help try to figure out the problem you're having. There are so many settings in Civil 3D it's difficult to pinpoint without it.
Michael Hurtado
Designated Support Specialist
Michael Hurtado
Message 4 of 8
<br><!--<br>.whitelabel { font-family: verdana, arial; font-size: 10px; font-weight: bolder; color: white; }<br>.label { font-family: verdana, arial; font-size: 10px; color: black; }<br>.filelink { font-family: verdana, arial; font-size: 10px; font-weight: bolder; color: blue; }<br>--><br>
Sender: ebarnes@mckimcreed.com
Upload Date: 2016-03-17 13:09:56.0
Message: This is the drawing in question.
Click the following link to download your file(s).
Click to Retrieve File(s)
CR101-05920054 - Standard.exe
If the above link is not clickable, copy and paste the following URL into your browser.
https://www.sendthisfile.com/locb2tzi2oRJhHmOuXctYvcN
Note: These files will expire in 14 days from the time this email was generated.
Powered by www.SendThisFile.com
Message 5 of 8
Jeff_M
Jeff_M
A 717 MB exe file???? What is in this file??? Is it a self extracting ZIP file?
Jeff_M, also a frequent Swamper
Message 6 of 8
It's just one drawing but I did an etransmit to make sure you had what you needed. Don't think it's self extracting.
This e-mail and any files transmitted with it are confidential
and intended solely for the use of the individual or entity to
whom they are addressed. If you have received this e-mail in
error please notify the system manager. Please note that any
views or opinions presented in this e-mail are solely those of
the author and do not necessarily represent those of the
company. Finally, the recipient should check this e-mail and
any attachments for the presence of viruses. The company
accepts no liability for any damage caused by any virus
transmitted by this e-mail.
Message 7 of 8
Jeff_M
Jeff_M
Ed, thank you for being thorough, but, for future reference, you can exclude any Image files (sid, tiff). Doing so with this set of file would've saved 635mb. There are other unneeded files as well, but those sure would've helped.
As for the rims being 180' out of place, I'm not seeing that. The only one which looks suspicious is #53, it is 15' higher than the surface. I think that part of this structure's issus is that the pipe connected to it is 9' higher the the next pipe in the network, thereby forcing the rim to be a certain height above the pipe.
Message 8 of 8
Joe-Bouza
Joe-Bouza
I usually see that if I forget to assign a surface
Joe Bouza
Joe Bouza
Rail Community
