Ribbon commands missing
rwatson654
rwatson654
I’m missing Civil 3D 2018 commands from my ribbons, other commands are on the ribbons.  Civil 3D commands work at the command line.  What I have attempted to resolve the issue: 1) Attempted to change my Workspace Settings to Civil 3D (ribbons looks like vanilla AutoCAD).  There is no Civil 3D option just Drafting & Annotation, 3D Basic, and 3D Modeling.  Under the All Customization Files pull down there is no C3D.cuix;  2) Repair the install, was not an option in Windows Settings; 3) Tried to reinstall (without uninstall) but the install Civil 3D as already on the computer; 4) Tried to load the c3d.cuix but it appears I would need to transfer the menu.  Have not done this with the c3d.cuxi so not sure the best approach on this; 5)  Did some online research but have not found anything yet.
I think, but am not certain, the ribbons may have changed when I applied the patches/updates.
I could do a clean uninstall but have been trying to avoid this due to project schedules and having to re-customize.
Civil 3D 2018, latest updates
Civil 3D 2017, latest updates.
Win10
Replies (10)
user181
Hi @rwatson654,  Have you tried to load the Civil 3D menu with the MENULOAD command?
rwatson654
Yes, without any luck.
wfberry
Make sure you are using the proper Civil 3D startup icon.  Metric or Imperial
Bill
rwatson654
Did that too.
user181
Have you tried to reset to default settings yet?
Jeew-m
Dear Friend,
Have you tried with 'Run as administrator'.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
rwatson654
Had not tried that yet.  That did bring back the commands in the ribbon.
rwatson654
Yes
Ribbon under  DRAWING AND FILE IS MISSING ON TOOL BAR HOW TO BRING BACK
rwatson654
