Hi, I'm hoping someone can help.
I'm trying to use the RetainWallTapered assembly. It actually does exactly what its supposed to do by targeting the existing ground as needed. The problem is I need it to target a profile I've drawn instead. So when I remove the target option for surfaces and add the target option for profiles then the retaining wall disappears completely.
I'm trying to model a corridor that has part retaining wall for a certain height (profile target) and the remainder will daylight to existing surface.
Does anybody have any idea how to make it target a profile? (see attached images for clarification)
