Retaining wall in assembly don't show in corridor surface
alexander_07_11
Message 1 of 8
alexander_07_11
I have assemblies that have a retaining wall subassembly. The problem is that it doesn't show neither in the corridor, the corridor surface or the sections. What should I do to fix that?
Thanks in advance.
Replies (7)
Message 2 of 8
tcorey
If you can post the drawing, that would be far out.
If not the drawing, can you post screenshots of Subassembly Properties?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 8
alexander_07_11
Can I share it in private with you and then post the solution that we can get? Thanks
Message 4 of 8
cwr-pae
Off the top of my head with out seeing the model; Sounds like the code set doesn't have link styles that show in sections, model space and plan view types assigned to the retaining wall links. The retaining wall links have to be added to the datum and top surfaces and the surface set to override top or bottom links for top and datum surfaces, respectively.
Message 5 of 8
alexander_07_11
@cwr-paeI get what you're telling me to do but I just don't know how to do it. Can you explain me please? I haven't really worked with codes in assemblies.
Message 6 of 8
tcorey
Go into Section Editor. Go to Next Region until the section slider is in the correct region. This is the view at station 0+150.00.
Tim Corey
Redding, CA
Message 7 of 8
alexander_07_11
@tcorey  This is what I see at station 0+150.00 in the file I sent you. I don't know why.
Message 8 of 8
tcorey
I don't think you're looking at the correct region. Other regions can include that same station.
Tim Corey
Redding, CA
