If I have multiple similar repeating strata for example,
CL | CL <---- Repeats
GW | GW
CH | CH
CL | CL <------ Repeats
would I need to change the geological code in the geological descriptions file? In this case I am referring to CL since it repeats twice in two borehole.
For example would I need to import something like this referring to the csv file submission under geological code,
CL | CL
GW | GW
CH | CH
CL2 | CL2
Any advice would suffice. Thank you! If more information is needed or clarification please let me know!
Solved by Udo_Huebner. Go to Solution.
Yes, in case of a repeated Strada you have to use different codes CL, CL1,CL2....
The software can not connect the points in the best way a geologist could do it.
This video shows similar questions to solve.
Even if Holebase SI has some more Features than Geotechnical Module, you could solve lenses manually with additional Featurelines. Keep in mind, the Geotechnical Module does never create the correct Strada out of the box with only a few boreholes.
https://www.youtube.com/watch?v=4eMsUiYBhuE
