remove this kind of TIPs
essam-salah
essam-salah
hi dears
i wanna remove this kind of TIPs (attached picture).
thanks in advance
Replies (7)
M_c3d
OPTIONS > AEC Editor tab > Solution Tips > uncheck DRAFTING.
essam-salah
@M_c3d I want to remove only this kind of Tips not all solution tips.
Jeew-m
Dear Friend,
I hope these links would help you to understand the issue well. Its been contributed by top class Civil 3D professionals. As a solution (indicated in the second link) you might uninstall the update if you are using C3D 2017.
https://forums.autodesk.com/t5/civil-3d-forum/overridden-text-warning/td-p/6497050
https://civil3dplus.wordpress.com/2016/08/14/civil-3d-2017-sp-1-and-the-glyphs-it-brings/
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
essam-salah
@Jeew-m im using C3D 2018 sir
I do believe that is a warning symbol. Select the symbol, rt click, select properties, display tab. Near the bottom of list is the warning entry. Turn it off
essam-salah
@Anonymous I can't find warning list in right click
Select item warning is attached too then rt click and go to properties of item its attached too. In the properties dialog go to the display tab. You will fill the warning listed there. Shut off the lightbulb.
