Rick, where do I start? I love it when guys like you profess to know EVERYTHING about a program and not even bother to think that there might be others out there who might need or want to program the software to function in a different format then what YOU profess is the best way to set it up.
Now that the tune of this post is set, let me share a little insight as to where your programming knowledge is lacking, and you my little buddy should really be sure you know what you are talking about before you do your best to school someone:
1. You state that Description Keys are not for Line work. I never mentioned that they are for linework, you said that. However, Description Keys are exactly where you program in HOW you want your line code and field coding to function/position, in other words, start, stop, curve, move position of a word, etc. You can read all about this in the help file if you like.
My coding that you seem so eager to put down allows for several options to occur at one point and offers a heck of a lot more flexibility within the program then your stock setup ever will.
I think I will stick with my coding because I LIKE the way it reads and so does my client.
2. You stated that the coding for Line work belong in the FPD, although this is quite true, I do not recall even mentioning that it wasn't. An who's to say I haven't customized the heck out of my codes so that all of my Lines have their own styles so that they can be control individually or as a group, it's just mind blowing when you get out of box you put yourself in.
3. You state that I am trying to control my points with layers. You are very observant and I give you a C for effort.
But let me ask you something, what do your clients that need your base survey do when they want to display say all of the Utility Points with Descriptions (and I do not want to see your stops and start now) and say also the Road Shots the same way when they do NOT have C3D?
Hows your one layer Node theory holding up now? Yah, I think I will stick with my few layers.
You and I both are here because of one thing, we want to help folks, but when you post on someones post, make sure you know what your talking about, do your homework, it only take a few minutes to verify what your saying is true or not, and your post is really lacking here on the ORIGINAL subject, and do we remember what that was?
How to REMOVE the Line Code Description Keys.
Not how to properly Program the Description Keys.
Now if you wanted to offer something useful to the post; I would have loved to have heard how you ran a test and your Line Code descriptions did not show up with alpha coding. Because it really should work with Alpha Coding, it is just not on my 2016 version.
I just wanted you know, there are folks out here who just might do things a little differently then you do.
I have worked with surveyors all over the US and Canada, and one thing that I can tell you is this...
Nothing is constant in surveying except the math.
Hope that you go back and take anther look at the Description Keys functionality, who knows you might learn something new and exciting and stay out of the way of those of us who are only trying to help folks who think a little differently then you, and might have the same issue that I was having when I wrote the original post.
Now I know that you and some others out here are going to say play nice, to that I say:
Just read the back 1st ladies jacket.
Com'on, that was worth a chuckle.
