REMOVE SMALL OBJECTS / POLYGONS
sanetdikkumbura1950
sanetdikkumbura1950
How to remove small objects (less than 50 square feet) in this drawing without SURFACE CREATE?
Accepted solutions (3)
Neilw_05
You can use QSELECT, polylines with area < 50, then delete.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
sanetdikkumbura1950
Hi, @Neilw_05 Can you explain how I do it?
Thanks.
Udo_Huebner
If these white rounded objects are polylines, then use
Command: QSELECT
Otherwise upload the drawing, or make at least a screenshot with one of these small objects selected (while property palette is open, to see the properties).
Gruß Udo Hübner (CAD-Huebner)
Shevaniol95
1. QSelect Command
2. Choose From Object Type Polyline
3. Choose From Properties Area
4. Choose From Operator Less Than
5. Enter Value 50
Ashraf E. Moures, F.E.
Highway Survey Engineer
LinkedIn | Facebook
Select Accept as Solution and click on Like
sanetdikkumbura1950
The work was done. It is successful. Thank you so much.
sanetdikkumbura1950
Thank you
