Remove or hide border from Pdf underlay
bcsurvey
bcsurvey
Can I remove or hide the border from a Pdf underlay?
I can't even seem to explode it.  While putting several utility details on one sheet, the OCD grid mentality takes over, but getting them to line up without their borders requires a viewport for each one which takes time.  If I can somehow lose the borders, it could be done quicker in one viewport.
Civil 3D 2019 (6.1)
Windows 10 Pro (21H2)
(i7-11850H @ 2.50 GHz)
32GB RAM
NVIDIA RTX A2000
Use, PDFFRAME < 0 >
doni49
I like to use setting 2 below that way I can see on screen where the boundary is (and manipulate it if need be) but it still prevents it from plotting the frame (or as you called it, the boundary).
Determines whether the PDF underlay frame is visible.
The FRAME system variable overrides the PDFFRAME setting. Use the PDFFRAME system variable after the FRAME system variable to reset the PDF frame settings.
Value Description
0  The PDF underlay frame is not displayed or plotted.
  The frame temporarily reappears during selection preview or object selection.
1  Displays and plots the PDF underlay frame.
2  Displays but does not plot the PDF underlay frame.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
bcsurvey
I was close.  All I could think of was tframe from years past, but it didn't do squat.
Thanks!
Civil 3D 2019 (6.1)
32GB RAM
NVIDIA RTX A2000
Yeah at first i was thinking image frame but then i remembered about that pdf has its own. Glad i finally solved one lol.
hi mate,
where did you get this system?
is it custom made?
how much is it?
bcsurvey
UUUHHHHHHHHHHH , , , ,
like . . . wrong forum 'n stuff?
Civil 3D 2019 (6.1)
32GB RAM
NVIDIA RTX A2000
