Civil 3D Forum
Remove extra spaces in Full Description when using description keys
1 REPLY 1
206 Views, 1 Reply
Hey,
So I'm using for my description keys for trees that I'm importing, I have the format set to $1" $2 (Full name of tree), ex: $1" $2 SWEETGUM with the raw description as GUM 15 TWIN. It then displays as 15" TWIN SWEETGUM. The problem I'm running in to is that not every tree is a twin, triple, or cluster and when that end component is left out of the raw description (ex: GUM 15). an addition space between the size and the tree name will show up. Is there a way to remove the extra space from showing up or is there a better way to do this.
Thanks in advance,
Keith
1 REPLY 1
rl_jackson
You'll most likely need different key and code for the twin triple and cluster like GUM2 GUM3 etc...  There are certain limitations to keys and your hitting one of them.
Rick Jackson
Survey CAD Technician VI
Rail Community
