Remove Border of the section view in Civil 3d
I am trying to remove the border outside the section view but couldn't find any relevant option in section view properties or section view styles.
 For reference I have attached a screenshot.
Jeff_M
That appears to be the Sheet Border of the SectionView Group Plot Style.
Jeff_M, also a frequent Swamper
Grover_Puma
Here I send you all the steps to follow. If I solve the problem, like it and accept the solution, please, this helps many to find a quick solution. Thank you
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
M_Obradovic
It green line should be section  buffer. You can turn off in section view stile then display and find buffer on the bottom.
Thankyou, the solution worked.
 I have one more question, what if I want to increase / decrease the size of the border offset?
M_Obradovic
If You want to increase or decrease follow next speps. 
Thanks, it worked for me.
