Crash publish from the shetset manager - Civil 3D 2021
Edwin.Saez
Advisor Advisor
Edwin.Saez
Hi everyone,
It happens to someone else that when you try to publish in several pdf files, from the sheetset manager, does the civi 3d freeze?
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
AdammReilly
Can you give some more information on the freeze/crash?
Are you publishing in the background?
In what method are you publishing? Using sheet set overrides or from the publish dialog box?
Is it when publishing every sheet in a set? or a specific sheet?
Have you tried doing one sheet at a time?
Do the sheets have any external links? (inserted excel spreadsheets can cause a freeze because of a dialog box that isn't always visible when it opens)
Adam Reilly
Civil 3D 2026
Creator A16 AI+ A3HVFG
Windows 11 Pro
AMD Ryzen AI 9 365 w/ Radeon 880M
LinkedIn
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
Civil 3D Certified Professional
