Remove a row in tables
JoeKidd33
Message 1 of 11
JoeKidd33
We are using Civil 3d 2018 and when clicking on a table and choosing remove items from the ribbon, nothing happens. The command REMOVETABLESELSETBYLSTYLE shows up in the command line, but it goes back to a blank command line.
Replies (10)
Message 2 of 11
Hidden_Brain
seems to work for me in 2018 SP2.
Message 3 of 11
JoeKidd33
I had SP2 installed, but tried uninstalling and reinstalling. Still does not work.
Message 4 of 11
Hidden_Brain
hmm, is it just that drawing?
Message 5 of 11
JoeKidd33
No. tried multiple drawings, on multiple computers.
Message 6 of 11
Hidden_Brain
i think i know what it is, you can remove rows from table that was created from a selection, but not from a table that had everything.
for example, i can remove rows from a points table which was based on selected points in a group, but cannot remove when the table is created for the entire points group. same for pipe structure tables.
Message 7 of 11
JoeKidd33
Bingo, that was it. Thank You!
Message 8 of 11
Hidden_Brain
I do not quite understand the logic behind this feature.
if i have multiple structures spanned over multiple sheets and i need to create tables by sheet, i have to individually select the structures one at a time on screen and then create tables.
vs.
if i could remove structures from a complete table, i could simply create an all out table, then select the rows there to remove and done. e.g. i could not rename all the null structures so that they are together in the table (Structure-1, Structure-2 etc.) as opposed to my inlets (IN-1, IN-2...), and then easily remove them from the table.
Message 9 of 11
JoeKidd33
I agree, the tool seems flawed. I love being able to edit the rows because reselecting lots of structures is time consuming. Would be a lot quicker to create by network and use the split table option to approximate how many structures per sheet. Then, remove or add as necessary. Seems like a good wish list item for 2020.
Message 10 of 11
OliverE
Hey any update on this? or is this tool still useless for large networks?
Cheers,
Message 11 of 11
dmpe
I haven't upgraded to 2022 yet, but I assume this functionality has not been improved?  It's ridiculous to have to go around and select everything for a table...why can't we delete items when table created from network??!
