Referencing dgn file into DWG file?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everybody,
I've been trying to reference a dgn file from another department into mine dwg file since I don't use Micro Station. I have tried 2 ways:
1. Import --> opening the file --> Import into current drawing - Attach as dgn Underlay , in this case I can edit the layers, but the problem is if the main dgn file is changed I can't get the updated file by reloading it in XREF and I need to re attach it and do all the process again.
2. Attach (Under Reference tab) --> Select the drawing --> Attach it as dgn file. The problem is I don't have access to the layers and not be able to turn the layers that I don't need off.
I appreciate if you can help me with this matter.
