All great comments from everyone. The solution is likely wrapped up in what you're trying to deliver. Do you need an ortho-photo geo-rectified with ground control or not? Recap can do this but establishing the control does not give you confidence in the accuracy. Other applications are better in my experience.
Do you need a point cloud to generate a TIN? Again, presuming you're on a datum with ground control, recap is tough to use. Pix4D does a great job. Infraworks does a far better job of turning any point cloud into a surface than C3D could ever do.
In general, Recap is not intuitive until it is intuitive. My Pix4D experience has actually been through another service called SiteScan. That's more of an end to end solution than just photo processing. It takes the photos and processes them in the cloud using P4D engine and generates all the deliverable types you want in about 2 hours for 200 photos with a report from P4D showing accuracy/tolerances. And all the data is available all the time and can be shared without having to email / FTP large datasets. It also has great analysis tools built into the system for measurements, establish control (including assumed datums), volumes, etc.
But for all that functionality, its an annual subscription. If you're doing one drone job a month, it's probably not worth it. You'd do better to just own P4D. But if you're doing 2 or 3 a week and maybe doing construction documentation... SiteScan is a steal.
Side note, we are a dealer for SiteScan, but the need for that type of service is what drove us to be a dealer for it. They are proactive in development. It is not the same as it was 2 years ago or even 2 months ago. They are constantly adding functionality each month that addresses the communities needs.
Anyway... more information for you to make a decision. Good luck!
Kevin
Kevin Spear, PE
