Raise/lower surface based on a grading group
craig_leat2KUVH
craig_leat2KUVH
I have several abutting platforms at different heights. These are described with feature lines of appropriate elevations. The feature lines (all closed polygons) have infill gradings and the gaps between the platforms have infill gradings. The perimeter of the development has a grading from the edges of the platforms to EGL. A surface was created from the grading group.
I wish to balance the cut/fill by raising/lowering the surface. When using RAISELOWERSURFACE the perimeter grading does not change. It still shows cut and fill banks, even though I have raised the surface sufficiently to have fill only. I notice the elevations of the feature lines have not changed. I could raise/lower each feature line, but that seems rather tedious. What am I missing here?
neilyj666
I'd be a little wary especially if all these are in the same site as this sounds like a recipe for a major crash - ensure you have a backup version before changing things
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
EliANewlines
Raise/lower surface doesn't alter the feature lines/grading groups defining the surface. Because the surface gets raised uniformly, whatever slopes you had before, are going to remain after. In general I would recommend only using RAISELOWERSURFACE when there's a datum change or similar. In your case, you can raise all the feature lines with one command, by selecting all of them and using RAISELOWERFEATURES.
craig_leat2KUVH
Yes, RAISELOWERFEATURES works with multiple feature lines selected - thank you!
