Civil 3D Forum
"INSERT" favorites tab
5 REPLIES 5
dhenderhan
330 Views, 5 Replies
Does anyone know how to import blocks to the favorites/libraries tab on 'INSERT' from previous versions? I found the path from previous version install and tried to copy the block dwg's to the current version install folder, but it didn't take.
David E. Henderhan, PLS
Civil 3D 2025
Dell Precision 3660 - Windows 10 Pro 64-bit
Intel (R) RTX A2000
12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
128 GB ram
Labels (1)
5 REPLIES 5
I assume you are referencing the blocks palette with the INSERT command (thought you meant the insert ribbon menu for that).
Autodesk has a workflow for that posted here: https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-7D4C6A3E-A942-4BA2-BCCA-AAF842A7F17F
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
I am, thanks!
Not really interested in working with the cloud, so I guess I'll just go find them again.
Civil 3D 2025
Intel (R) RTX A2000
128 GB ram
rgrainerVXXAM
in reply to: dhenderhan
How many block are in your favorites location?
dhenderhan
in reply to: rgrainerVXXAM
Well, it appears that in my attempt to copy the directory over, I've wiped out the favorites in the old version as well, so I'm not sure. probably a dozen or so, but no biggie.
Civil 3D 2025
Intel (R) RTX A2000
128 GB ram
rgrainerVXXAM
(defun getmymodalz ()
 (setq orthm (getvar "orthomode"))
  (setq osmod (getvar "osmode"))
   (setvar "osmode" 0)
    (setq osz (getvar "OSNAPZ"))
    (setq clay (getvar "clayer"))
   (setq cecho (getvar "cmdecho"))
  (setvar "cmdecho" 0)
 (princ)
(defun resetmymodalz ( )
 (setvar "cmdecho" cecho)
  (setvar "osmode" osmod )
   (setvar "orthomode" orthm)
  (setvar "clayer" clay)
  (setvar "OSNAPZ" osz)
  (setvar "cmdecho" 1)
 (princ)
(defun lay-favorite-maker ()
	(if(= nil (tblsearch "layer" "company-favorite"))
      (command "-layer" "m" "company-favorite" "c" "6" "company-favorite" "LT" "HIDDEN2" "company-favorite" "")
      (command "-layer" "set" "company-favorite" "")
 (princ)
(defun c:fave1 ( / isc ipt)
 (getmymodalz)
 (setq isc (/ 1 (getvar "cannoscalevalue")))
 (setq ipt (getpoint "\nSpecify fave one Insertion point?:"))
 (prompt "\nRotation Angle")
 (lay-favorite-maker)
 (command "-insert" "fave1" ipt isc "" pause "" "")
;; (command "explode" "l" )
;; (command "ddatte" "l")
 (resetmymodalz)
 (princ)
It's a little later and you've probably fixed your issue, but here's something for you to try as a work around or alternative method for getting to your favorites.
Either create a block named fave1 or change the name of the block that is being used in the code to one of your existing blocks.
if this is acceptable, then just make a copy of the code and create 11 more fave programs name them all the way you want
Rail Community
