"Drawing cannot locate the project"
I had a file crash that has a couple of other data shortcuts in it and when I try to reopen or recover it I get a notification in my command bar "Drawing cannot locate project" the file also freezes up. I can move my cursor around but I have no control of autocad and have to use task manager to shut down the program. I have no problem opening any of the other files that contain the same data shortcuts and I also Have no problem opening my Sheet Set that has that file x-ref in it.
*side note before my file crashed I did not have those merging contours in white and green I had them as the red and grey design and the ones you can faintly see behind them are the proposed yellow and green. not sure why that is different now or if that helps.
Any ideas?
Brandyn
