question about Axis of Rotation (AOR)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi.
We have a new project and we must use the AOR.
We are using 4 LaneSuperElevationAOR subassemblies with the property: Potential Pivot= Yes and the properly Use SuperElevation for each case.
About the alignment, in the "Calculate SuperElevation" dialog box, this is our settings:
-Undivided Crowned.
- Pivot Method: Inside of curve.
This project is a 2+1 road:
https://en.wikipedia.org/wiki/2%2B1_road
But there are 5 pivot methods:
-Center BaseLine.
-Inside of curve.
-outside of curve.
-Left side.
-Right side.
But the "Inside of curve" method is only for curves I think and we need also a method for the straight lines at the same time.
Perhaps, we need this pivot method: Inside of the curve AND Rigth side.
"The right side" would be only applied in the portions where there are lines in the alignment.
Any ideas?
In addition, I would like to know where I could get more info about AOR concept in Civil 3D.
Thanks in advance.
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
