Civil 3D Forum
QTO - Is it possible to use parameter values from pipe network in formulas?
5 REPLIES 5
533 Views, 5 Replies
I'd like to create a pay item for the trench of pipes. I understand that I can use the "part depth" to get the mean depth of the pipe, but I need to add to the equation the pipe diameter so that I can calculate the volume of earth. Is this possible?
5 REPLIES 5
Jason.Ferrelli
In the pay item formula dialog box, the "Part Depth" property should account for the outer diameter as part of its expression. This is calculated as (max cover + min cover)/2 + the part OD.
Jason Ferrelli
in reply to: Jason.Ferrelli
Thank you for your answer!
I do realize that the part depth parameter accounts for the pipe size, but what I wanted to do was to create a trench pay item that would calculate the earthwork for those pipes. The formula would have to be: Part Depth * (OD + 0.2) * Item Length.
My problem with the above formula is that I can't have the OD parameter to be able to build that formula...
Guess it just isn't possible, right?
Jason.Ferrelli
That is correct that there is not a dynamic OD property that you can add to that expression when using the pay item formula editor.
If you have multiple pay items for a certain pipe sizes, could you manually add that numerical value to the expression for those individual pay items?
Example:
Pay time = 12" conc pipe with OD of 16"
Formula = Part Depth * (16 + 0.2) * Item Length.
Jason Ferrelli
oooh...hadn't thought of that! thanks! yes, that's a perfecly reasonable workaround
kudos!
Jason.Ferrelli
No problem at all, glad I could help.
Have a great one!
Jason Ferrelli
Rail Community
