QTO - does it actually work??
neilyj666
Mentor Mentor
Message 1 of 10
neilyj666
I haven't used QTO for some years as I was never totally confident it reported the correct things so tried it again in 2024 and still unconvinced.
The 3 polylines have had a pay item added and yet the QTO report shows 8 items with the 2nd, 5th and final lines being the correct ones
Anyone got any ideas - I'm think of using property sets or simply Data Extraction as these work with no issues
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (9)
Message 2 of 10
brian.strandberg
I think QTO works very well for pipe networks when your pay items are assigned to the parts list.  QTO also works well for corridors.  Everything else, not so much.  I think its more of a headache than necessary.  Project Explorer also works great for counting blocks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 3 of 10
neilyj666
...none of which I'm trying to do a QTO for - just simple AutoCAD polylines.
I just used Property Set data and it worked with no issues - reported via a Power Query in Excel
Message 4 of 10
bill2NMLX
Sad part QTO has been out for 15 years and not one major improvement.  Not worth the time to setup and no way of verifying the results if you do.  Faster and more accurate to just do it manually. Sad!
Bill
Message 5 of 10
brian.strandberg
Property set data is better and more reliable than QTO.
Message 6 of 10
neilyj666
Certainly I have more confidence in the result if I do it manually or with Property Set data
Message 7 of 10
neilyj666
This is the conclusion I am rapidly coming to...!!!!
Message 8 of 10
Joe-Bouza
DE is the way for me
Joe Bouza
Message 9 of 10
adavisCX29X
Can you explain how you did this or give a link to instructions? Working on quantity takeoffs for a cost estimate now. Also, is there a way to get the start and end stations for something you are getting the area or volume of? Right now I'm just making polylines from the start and end and using that for alignment stations.
Message 10 of 10
Joe-Bouza
I have had this happen and have the same level of confidence. And some of the can be traced back to me/ users.
By chance, and this has happened to me, if you hove the polyline does it show more than one application of the QTO?
Although your listing looks like different objects all together
Joe Bouza
