Proposed building footprint with Proposed contours already
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working on an existing site plan trying to create a proposed site plan with a new building on site. I have the proposed building footprint elevation and all of the proposed contours figured out. When it comes to creating a surface I'm just not sure as what to put the foot print as on the surface. I've tried multiple things but noting have inserted it as a flat surface with the grading around it. Some of the options worked but yet I go to use a volume analysis for cut and fill comparing the existing and finished grade and the cut and fill values are not correct it is still trying to cut section of the building pad when it should be getting filled for the whole building pad section.
