PROPERTY SETS DEFINITION FOR CIVIL3D OBJECTS NOT SHOWING CORRECT VALUES
Hi All,
I was trying to automatically populate some civil 3d pipe properties like the pipe dia and pipe material to the extended properties, I got the VB script from one video in youtube and also from one AU class, But even after replicating the same script, my properties are not getting updated. Below is the script which I used.
RESULT="--"
On ERROR RESUME NEXT
Set oApp=GetObject(,"AutoCAD.Application")
Set oCivilApp=oApp.GetInterfaceObject("AeccXUiLand.AeccApplication.14.0")
Set obj=oCivilApp.ActiveDocument.ObjectIDtoObject("[ObjectID]"]
RESULT=obj.PartDataRecord.FindByContext(401).Tag
Can anyone help to fix this issue.
Accepted solutions (3)
Udo_Huebner
Are you using civil 3d 2021? Could you post a simplified sample file as dwg?
Gruß Udo Hübner (CAD-Huebner)
I using 2020.3 version of Civil 3D.
I have attached a portion of my file in  the below link. Please let me know if that file is not working for you.
https://www.dropbox.com/s/q42x35vr3cjvwih/C3D_CASE.dwg?dl=0
Thank you in advance.
Udo_Huebner
This code should work with 2020
RESULT="--"
On Error Resume Next
Set oApp=GetObject(, "AutoCAD.Application")
Set oCivilApp=oApp.GetInterfaceObject("AeccXUiPipe.AeccPipeApplication.13.2")
Set obj=oCivilApp.ActiveDocument.ObjectIDToObject("[ObjectID]")
RESULT=obj.PartDataRecord.FindByContext(300).Tag
With Civil 3D  2021 you have to use 13.3 instead of 13.2
You can type in Command: AECVERION to determine the current AEC version number (14 is not out yet).
Additional hint: install latest AutoCAD Update 2020.1.3 as well. Q.47 means you never updated the Core AutoCAD functionality.
Thank you so much Udo..
Hi Udo,
Can you please help me with a same type of code to get the name of the structure.
Below is the structure name that i am trying to get to the extended data.
Udo_Huebner
>> Below is the code which i have tried, ...
1. To access pipe network data, don't use
GetInterfaceObject("AeccXUiPipe.AeccXUILand.AeccApplication.13.2")
but use
. To access Structure name simply use
RESULT=obj.Name
Keep in mind that ObjectID must be defined as well.
Screenshot from German Civil  2020.4 VersionScreenshot from German Civil 2020.4 Version
