Property Sets and invert elevation
hericson
Message 1 of 28
hericson
I'm trying to use Property Sets for my structures and pipes. Now I want to add invert elevation in the start and end points but can't understand how to do it. I'm using this code for other properties:
RESULT="—"
On Error Resume Next
Set oApp=GetObject(, "AutoCAD.Application")
Set oCivilApp=oApp.GetInterfaceObject("AeccXUiLand.AeccApplication.11.0")
Set obj=oCivilApp.ActiveDocument.HandleToObject("[Handle]")
RESULT=obj.Name
I found this post about invert elevations but it doesn't make sense to me how to do it: Help With Property Sets--Invert of Pipes
Anyone who can help me bring some light on this?
Replies (27)
Message 2 of 28
ccedilloYSFN7
Any luck? I'm having the same issue..
Message 3 of 28
samir_rezk
Hi @ccedilloYSFN7
please elaborate on what it isy you’re trying to create a propert set for. Is it the structure connected pipes or the pipes them selves?! Also what is version are you using, the code is dependent on the version of civil 3d.
thsnks
Samir Rezk
Technical Support Specialist
Message 4 of 28
ccedilloYSFN7
Hi @samir_rezk,
I am trying to create a property set that would allow me to view the Start and End Invert Elevations a Pipe (Pipes themselves) in Civil 3D 2018. I have been using the VB Script code (shown below) to bring in other Geometry but cant figure out the code for Invert Elevations.
RESULT="--"
Set oCivilApp=oApp.GetInterfaceObject("AeccXUiLand.AeccApplication.12.0")
RESULT=obj.StartInvertElevation
Message 5 of 28
samir_rezk
I want to explain a little bit about how to write the VBA code that's required to read Civil 3D object properties because there is a couple of things that you need to be aware of depending on what you are trying to accomplish:
example code is:
RESULT="—"
(common VBA technique to publish the outcome of the code at the beginning)
(this ensures that if the code fails the program does not crash)
(Civil 3D is built on top AutoCAD so we must get access to the acad application first)
(this is where it starts getting tricky because there is 4 major civil application that can be listed here, then you must specify the version depending on what Civil 3D year version you are running)
The 4 Civil apps are
  • AeccxUiLand (all other Civil 3D Objects)
  • AeccUiPipe (for Pipe Networks)
  • AeccxUiRoadway (for Corridors)
  • AeccxUiSurvey (survey Figures)
right click and go to properties/details tab to identify the version no. it is different per the Civil 3D year version. (Civil 3D 2019 is v. 13.0)
(you must have the Handle field included in your property set! this is going to be an automatic field that must be added prior to creating this formula field, it's necessary because it creates the link between the object designation in AutoCAD and  it's Civil 3d properties)
RESULT=obj.Name
(finally we are going to reveal the property of the Civil 3d object that we want to read)
the best and easiest way to get a complete picture of what properties you can read and what to write on this line is to run the DumpObject.LSP provided at http://www.lee-mac.com/dumpobject.htmlObject.
this lisp routine will result is an example listing as the following that I generated by selecting a pipe object, as you can see you now have all the Civil 3D  Property Names applicable to a certain object and you can now use the property name as a Result in your VBA Code (note that the properties are different for each object so properties of a structure are different than those for a pipe)
Select object: ; IAeccPipe: Pipe interface
; Property values:
; Alignment = nil
; Application (RO) = #<VLA-OBJECT IAeccApplication 000001c5c35d8080>
; ClosestPointTo (RO) = ...Indexed contents not shown...
; Connectors (RO) = #<VLA-OBJECT IAeccConnectors 000001c5c35d8da0>
; Description = "12 inch Concrete Pipe"
; DisplayName (RO) = "Pipe - (1)"
; Document (RO) = #<VLA-OBJECT IAeccDocument 000001c5c35d8590>
; EGLDown = 0.0
; EGLUp = 0.0
; EndPoint (RO) = #<VLA-OBJECT 000001c5c35d87a0>
; EndStructure (RO) = #<VLA-OBJECT IAeccStructure 000001c5c33b2990>
; EntityTransparency = "ByLayer"
; FlowDirection (RO) = 1
; FlowDirectionMethod = 1
; Handle (RO) = "86C8"
; HasExtensionDictionary (RO) = 0
; HGLDown = 0.0
; HGLUp = 0.0
; HoldOnResize = 0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000001c5c3bc5548>
; InnerDiameterOrWidth (RO) = 1.0
; InnerHeight (RO) = 1.0
; IsMaxCoverViolated (RO) = ...Indexed contents not shown...
; IsMinCoverViolated (RO) = ...Indexed contents not shown...
; Labels (RO) = #<VLA-OBJECT IAeccPipeLabels 000001c5c3c25eb0>
; Layer = "C-STRM-PIPE"
; Length2D (RO) = 115.963
; Length3D (RO) = 115.969
; Linetype = "ByLayer"
; LinetypeScale = 1.0
; Lineweight = -1
; Material = "ByLayer"
; MaximumCover (RO) = 0.0
; MinimumCover (RO) = 0.0
; Name = "Pipe - (1)"
; ObjectID (RO) = 42
; ObjectName (RO) = "AeccDbPipe"
; OuterDiameterOrWidth (RO) = 1.33333
; OuterHeight (RO) = 1.33333
; OwnerID (RO) = 43
; ParamsBool (RO) = #<VLA-OBJECT 000001c5c35d9f40>
; ParamsDouble (RO) = #<VLA-OBJECT 000001c5c35da420>
; ParamsLong (RO) = #<VLA-OBJECT 000001c5c35da480>
; ParamsString (RO) = #<VLA-OBJECT 000001c5c35d9fa0>
; PartDataRecord = #<VLA-OBJECT IAeccPartDataRecord 000001c5c35da840>
; PartFamily (RO) = #<VLA-OBJECT IAeccPartFamily 000001c5beb87e60>
; PartSizeName (RO) = "12 inch Concrete Pipe"
; PartType (RO) = 10
; PlotStyleName = "ByLayer"
; PointAtParam (RO) = ...Indexed contents not shown...
; Position (RO) = #<VLA-OBJECT IAeccPoint3d 000001c5c35da930>
; ProfileNetworkParts (RO) = #<VLA-OBJECT IAeccGraphProfileNetworkParts 000001c5c3c25910>
; Radius (RO) = 0.0
; ShowToolTip = -1
; Slope (RO) = 0.01
; StartPoint (RO) = #<VLA-OBJECT 000001c5c35db350>
; StartStructure (RO) = #<VLA-OBJECT IAeccStructure 000001c5c33b6190>
; STMPipeMetadata = unsupported result type: 65
; Style = #<VLA-OBJECT IAeccPipeStyle 000001c5beb894e0>
; SubEntityType (RO) = 0
; Surface = nil
; SweptShape (RO) = 2
; TrueColor = #<VLA-OBJECT IAcadAcCmColor 000001c5c3bc61a0>
; Visible = -1
; WallThickness (RO) = 0.166667
Hope this helps,
Samir Rezk
Message 6 of 28
Buzz0m
This post is pure gold! Thank you @samir_rezk !!
Message 7 of 28
Hi
RESULT="--"
Set oCivilApp=oApp.GetInterfaceObject("AeccXUiPipe.AeccApplication.13.0")
RESULT=obj.aec_pipe_end_invert_elevation
Dear colleague's what would be the correct obj.result code to get pip invert elevation?
Thank you in advance
Message 8 of 28
samir_rezk
Hi @Anonymous
Invert Elevation is not an available property that can be added to a property set. the DumpObject Lisp does not show an applicable property for inverts. I also double check the API documentation at the link below, but unfortunately it is not available!
http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/AeccXPipeLib__IAeccPipe.htm
Sorry,
Samir Rezk
Message 9 of 28
samir_rezk
Hi @Anonymous
I stand corrected! It has been bugging me all day today, on how to calculate the Invert Elevations for a Property Set! considering that I noticed there is a StartPoint and EndPoint API Properties available, granted these are points for the center of the Pipe not the Inverts.
Here is the Code that can calculate Invert Elevations based on (start point elev minus 1/2 the pipe size) my application versions are for Civil 3D 2020, so make sure to revise as necessary for your version!
RESULT = "-"
Set oApp = GetObject(, "AutoCAD.Application")
Set oCivilApp = oApp.GetInterfaceObject("AeccXUiPipe.AeccPipeApplication.13.2")
Set Aec = oApp.GetInterfaceObject("AecX.AecBaseApplication.8.2")
aec.Init oApp
Set obj = oCivilApp.ActiveDocument.HandletoObject("[Handle]")
spos = aec.ActiveDocument.Utility.ConvertToVariantArray(obj.PointAtParam(0))
RESULT =(spos(2)-obj.InnerDiameterOrWidth/2)
I can't say that I totally comprehend the whole code but some of it makes sense!
Need to give credit to an earlier post for the original VBA Code found at:
https://forums.autodesk.com/t5/civil-3d-customization/get-point3d-values-in-property-set/m-p/7963513...
Sample drawing containing property set definition attached.
reminder to use AECPSDAUTOATTACH system variable to auto attach Property sets to objects.
hope this helps,
Samir Rezk
Message 10 of 28
Thx you verry much! You are a real wizard! Have an awesome day 😁
Message 11 of 28
hericson
Excellent! Finally a solution! Thanks!
Message 12 of 28
ishaq03
Samir
 my application versions are for are for Civil 3D 2020 I am using the same code for 2022 version can you provide me this code in 20222 for invert elevation start & end along with pipe length. This content I need urgently required for my  project please do the favor for me rapidly, waiting for your feedback.
Message 13 of 28
samir.rezk
Autodesk Support
Autodesk Support
@ishaq03
Use the same code from message 9! just replace the product versions once you review the Civil 3D ABOUT command:
  • Use 13.4 (Civil 3D 2022) instead of 13.2 (2020)
  • and 8.4 (AutoCAD Arch. 2022) instead of 8.2 (2020)
Hope this helps,
Samir Rezk
Message 14 of 28
ishaq03
After adding the code as per your advice I am unable to get get invert level check attached pic for your references.
Message 15 of 28
samir.rezk
Autodesk Support
Autodesk Support
@ishaq03
Make sure to add an Automatic Property for the object Handle first, then in the invert code delete the [Handle] text and double click to add it again (the text should have a grey background), this make the connection between the code and the Civil 3D object to interrogate. Review message 5 for an explanation!
Samir Rezk
Message 16 of 28
ishaq03
Thanks for your sample video it's help me to get Start Invert elevation. But please explain me how to get end invert elevation.
Message 17 of 28
samir.rezk
Autodesk Support
Autodesk Support
Hi @ishaq03
Review the screen capture in message 9 for the End Invert. There is only one parameter to change for the end of pipe information! I noted it on the screen capture!
Samir Rezk
Message 18 of 28
ishaq03
I Know I am giving trouble to you, but please can you Provide me any code for Pipe length to add in custom properties.
Message 19 of 28
ishaq03
Thanks samir, It's awesome Ones we will add handle object the information we can extract from Either pipe or Structure element. Thanks again
Message 20 of 28
jaanYPY4L
Can someone confirm this is not working in Civil 2022, latest update? Or is something wrong with my Civil... Its the same .dwg you uploaded.
