Property Set VB script code doesn't return value
jobin.e
jobin.e
I have a property set definition that has a value lets say 8605-GF-743-8.05-SQ-FSSS-081
I need to create 7 formula based property that returns the values separated by the underscore
for eg 1st property definition will return 8605, second will return GF and so on...
I created another formula based property definition that uses the mid function to return a portion of the string (see attached image).
But it doesn't return the desired value. Can anyone tell me what I'm doing wrong?
Regards
Jo
jobin.e
Never Mind.
Got it solved. Working code below.
