- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In the window PropertySetsDefinition, I am using the automatic definition "Volume" to calculate with formulas another object´s properties. For example, to calculate the length of a thin pipe, which was created with a corridor, I use the formula Length=Volume/(pi*(diameter/2)^2.
When I have to define the format of a property , I can select between the following options (s. column Format - Line Volume):
Translation: (2 Nachkommastellen = 2 decimal places // ganzzahl = integer).
It means, I can calculate the Volume with at most 3 decimal places.
I would need to calculate the volume with more decimal places (at least 5), in order to avoid errors due to the rounding (which are in my case significant).
Is it posible to do that?
Thanks you.
