When I create a 3D Polyline using the 3dPOLY command on my personal laptop it properly creates a line however when I check the properties tab after having created said line instead of showing as 3d Polyline and giving me the elevation data it only shows Polyline. I referenced a work computer with the same exact drawing to see if the same issue exists and it doesn't, the same exact line will provide elevation data for the said line as well as label it "3DPOLYLINE" in the properties tab on the work computer. I am unsure of what settings could be different. Any Ideas?
