Hi @erichSE95A,
Good day to you! Thank you for submitting your question in our discussion forums. In addition to the suggestions provided by our experts, this issue (Properties Palette) being positioned off screen issue is often a result of:
- Changes in screen resolution
- Changes in the number of monitors connected to the computer
- Change in monitor
Take a look at this article for troubleshooting steps:
AutoCAD palettes do not display or are placed off screen
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
