Properties panel dropdown menu issues
erichSE95A
erichSE95A
My dropdown menu for styles in the properties panel keeps moving off screen (see below). I upgraded to 2023 and am running into weird issues, this being one of them. PLEASE HELP.
brian.strandberg
Is this from the main properties panel or the quick properties (shown).
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
erichSE95A
Main properties panel
brian.strandberg
If its moving and the earlier link didn't help, I would reset Civil 3d back to defaults and see if it does it then.
You may also want to upgrade your graphics drivers.  I have seen weird things like this on old graphics drivers.
lim.wendy
Hi @erichSE95A,
Good day to you! Thank you for submitting your question in our discussion forums. In addition to the suggestions provided by our experts, this issue (Properties Palette) being positioned off screen issue is often a result of:
  • Changes in screen resolution
  • Changes in the number of monitors connected to the computer
  • Change in monitor
Take a look at this article for troubleshooting steps:
AutoCAD palettes do not display or are placed off screen
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
codyfrly63
This worked for me! I was going nuts because since I dock my pallet on the right I was unable to see the the drop-downs at all! I followed the article, then I re-docked and all is working now!
Edit: this was only temporary. It reverted to being an issue.
