I understand that horizontal geometry belonging to an alignment can be 'projected' or drawn on a profile view. My question is, can other objects, such that intersect the alignment for example, be projected onto the profile view?
This would be of a lot of help when trying to illustrate what roads my rail alignment intersects for example, and also, would allow the vertical alignment of my track to be designed more efficiently, as I could map station (train station) locations directly from the horizontal alignment, onto the vertical profile. The gradient at stations should ideally be 0% (or 1:500 for track drainage purposes), so it would help to know where those locations are precisely in the profile view (I know where they are in the horizontal alignment already)... as these locations will effectively act as the boundary conditions around which the rest of my vertical alignment will need to be designed.
Furthermore, is it possible to represent this sort of information (objects or lines intersecting my horizontal alignment) automatically in a band, beneath the profile view? Or is this getting a little too advanced? I'm a beginner after all. I don't want to get too absorbed into such details considering I've got deadlines to keep to. I could do it manually I suppose. It might just take considerable time considering I'd have to scale the distances in order to plot these details accurately on the profile view.
Solved by Jowennl. Go to Solution.
You can put points on the road crossings and project the points to your profile view.
I don't know of a way to label the projections in a band, but you can make an automatic label to go along with your marker point for the projected point in your profile view.
Joe Bouza
Hi John,
I believe what you are looking for is to project object to profile view and it’s been in Civil 3d since 2010 version.
You can project the following:
AutoCAD points, blocks, 3D solids, 3D polylines, AutoCAD Civil 3D COGO points, feature lines, and survey figures
You just need to be aware on projection style and projection labels style. (You can play around with this in the settings)
The most common I use is solid projection and I make sure I got the following below:
Please see this <you tube link> for guidance.
Please see this <Autodesk knowledge Link> for further information.
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
