As in --> Options > Tab-Files > Project Files Support Path >
Simply an exploratory question. I am posting to this forum because my other trails are turning cold.
Does setting paths, in PFSP, effect or even relate to Sheet Set Manager or Data_shortcuts(C3D) lately?
Thoughts, documents and links would be appreciated.
Thank you,
Bernie W.
Solved by chriscowgill7373. Go to Solution.
Not that I am aware of. To the best of my knowledge it only affects xrefs ./ images / pdf pathing.
I used a tool to export a sheet set .dst to .xml, if you are curious you can look it over.
https://help.autodesk.com/view/CIV3D/2024/ENU/?guid=GUID-BBE6FA4B-800E-4D7D-9D59-EDA24829C5E9 According to the help article for the PROJECTNAME variable, no.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
