Project Explorer quick export error
r_griffith
r_griffith
I'm trying to make a quick-export in the Project Explorer of an Alignement and Profile View using this method:
Than i get this error:
Project Explorer: Cannot export to AutoCAD DWG because there are 4 text styles in the current drawing which reference missing SHX files.
I've allready used *STYLE* to change all foreign text styles to known styles.
Anyone any idea how to fix this? Google has no answer on this one.
ianjchap
Hi @r_griffith,
If you can identify the name of the missing shape file you should be able to recreate the files (even if slightly different) to get around the error message.
Some more info here:-
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-cannot-fin...
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
adria_deborjaLCK4C
Observer
Observer
I am having the same issue. I have looked through text styles and there are no missing .shx files there. (No exclamation marks)
I have also done an audit and a purge and unloaded all my XREFs.
pobrienFNE96
Same as @adria_deborjaLCK4C and @r_griffith .
  • I used Reference Manager as well as Purge to try to figure out what wasn't linked. All green.
  • Verified that no text styles had font errors.
  • Changed all test styles with .SHX fonts to Arial.TTF
  • Still had same error shown above.
