Project Explorer Overflow Error
clarsenCNDZF
clarsenCNDZF
So I got my hands on C3D 2021 and downloaded the project explorer.
I am getting an issue when I try to view the assemblies tab in the Project Explorer, it produces a Overflow Error every time I try to select an assembly or any part of the sub assembly.
This can eventually leads to a fatal error.
I have submitted a report. Is there anything else I can do to attempt to fix it?
Wojtek_Garczewski
Hi @clarsenCNDZF
Thank you for your post.
Can you confirm that the error message is prompted in any file, or this is present only in a specific drawing?
Thank you,
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wojtek G.
Technical Support Specialist
Civil Engineering Solutions
clarsenCNDZF
So in doing some testing, the error occurs when using the LaneSuperelevationAOR subassembly and setting all of the depths to 0. I tried a couple of other assemblies and notice the error happens with some and not with others.
for example Lane Broken Back with depth set to 0 will produce the error.
Shoulders Extend All does not.
Wojtek_Garczewski
Hi @clarsenCNDZF . I tested myself and was able to reproduce it. I'm getting an Overflow Error too when trying to review some subassemblies with layer depth set to 0m.
I've already sent this information to our Developers for further investigation.
Thank you for notifying us about this behavior. If you have any additional questions, please feel free to ask.
Wojtek
Wojtek G.
