Profile views - Adding custom profile points and elevations
Alriddin
Alriddin
I have a profile view where the labels have been created to show offsets of 10m ahead of and behind the low points for specific profiles. These labels use expressions.
This first image shows where the labels have been created. But they are a function of the low point label, and only show the station value.
Is there a way to get those elevations to show in the profile data bands? I would imagine that this would require elevation points. But there is no way that I have seen, to create manual profile elevation points.
The only options available are the default geometry points.
Wojtek_Garczewski
Hi @Alriddin
Thank you for posting us.
It looks that can't be achieved automatically.
 You may place elevation labels manually, with Add View Labels -> Station Elevation, then select your Profile View and pinpoint the offset location.
Wojtek
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wojtek G.
Product Owner for Civil 3D
Civil Engineering Solutions
Jeew-m
This is kind of a tricky method.
Since you have the elevations marked on profile, you can create a profile from it.
Otherwise you can use create profile from file option.
Then create sample lines at the stations where you have the elevation points. You can use this video for it.
https://www.youtube.com/watch?v=1ahOJ_j004U
Then on profile view properties, you have sectional data-->sample line name and distance
Add this to band. Modify the style to add the elevations from new profile.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
