Announcements
Seperate Area cut for Structure Excavation of Lined Canal
Good Day to All,
I hope u can help me with how i can separate my area cut as "structure excavation" for my canal as shown in the attached screenshot. Im new with subassembly composer so im having a hard time, maybe you can help me how to make the links and conditions so that i can incorporate it to my quantity takeoff. Thank you in advance and hope you all safe this pandemic.
Accepted solutions (3)
tcorey
Post your subassembly file (*.pkt). Be sure to rename to *.zip before posting. This site does not accept .pkt files.
What I will be looking for is any Shape Codes you have added to the Subassembly. This allows you to quantify import. Link Codes will allow you to quantify cut/fill by defining those properties in Compute Materials command.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
ecfernandez
Hi, @Anonymous  have a great day,
You can solve this by doing this:
1. Create a Datum Surface for the bottom link of the canal, and then, another Datum Surface for the roadway. But, how to do this? Here it is the answer:
a. When creating the Datum surfaces, use different links for them. for instance: You can create the Datum surface for the roadway with the Subbase Sode since I could see that this is your deepest layer for the road; and the Canal Datum Surface with the Datum Code as you already created your surface in the drawing you attached. It Should be great if inside your PKT you put a special code for the bottom link of the canal so you don't have any problems when creating this surface.
b. Be careful, you might have to use some boundaries so you make sure those Datum Surfaces are representing what they have to. In the section views, the datum surfaces should represent each element as follows, see the image:
2. When computing materials, create two "Cut&Fill" materials, The first one is going to be:
First: EG surface as Existing ground and "Canal Datum Surface" as your Finished Ground Surface
Second: EG surface as Existing ground and "Roadway Datum Surface" as your Finished Ground Surface
Unfortunately, I couldn't do the process in your file since you didn't send the PKT File of the subassembly for the Canal. I hope you can do it, but if not, let me know and send me the PKT File and I'll help you achieve it.
My best Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
Thank You very much sir,
i'll send u the pkt file.
ecfernandez
Hi, @Anonymous  I had not seen your attached pictures the first time I answered, sorry. Now I think I understand what you want.
I have added some characteristics to your subassembly so you can have a shape (Code: "Cut Material") for computing that amount of cut apart from the other cut material that is computed from the comparison between EG and the Datum surface of your corridor.
Finally, I have added a "Top_Cut" code to the top part of the cut material shape that I created for the canal, and I have modified the code for the bottom part of the canal, which is not going to be "Datum" anymore but "Datum_Canal". By doing all of the previous tasks you can use the "Top_Cut" in your "Roadway Datum Surface" to prevent Civil3D creates the datum again below the canal and that material is quantified twice. See the image:
Give a look at the file and the PKT that I attach and please let me know if that was handy for you and solved your problem.
Camilo Fernández
LinkedIn
Very much appreciate your precious time in helping me with my problem. I will as soon as i get to work.
Thank You very much and keep safe!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
