Sorry, I'm not able to make a screencast while at work. (they frown upon it)
After watching Mike's video I realized that the slope information is being used in a profileview band. Bands can't use expressions, so that option is off the table.
Reversing the flow direction is an option. Select and piece of the pipe network in the plan. The ribbon will switch over to the network tools. In the Modify section there is a pull section of more tools. One of those tools is Change Flow Direction. Select that tool and it will prompt you to select two structures to use for determining the flow direction of all the connected pipes between them. Select the southern most structure as the UPstream and the northern most as the Downstream. Now the band will show the correct slope but not the + sign yet. Edit that band style and for the pipe slope property set the Sign to 'sign always (+-)'. That should do it.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
