Profile view pipe slope sign
shashimanandhar1417
Message 1 of 16
shashimanandhar1417
Could you help me to alter the sign of the pipe slope on my profile view. Currently it is "-" ve upward from start of pipe to end of pipe. How do I make "+"ve sign to upward slope from start of pipe to end of pipe. Currently I am using Civil 3D 2016.
Replies (15)
Message 2 of 16
CivilFlow
Can you please share a pic of your situation?
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Message 3 of 16
shashimanandhar1417
Thank you Mike for quick response. See the attached snapshot. The Gradient is "-" for upward slope from start of pipe to end of pipe. Can I reverse the signage of the slope.
Message 4 of 16
CivilFlow
I can help edit this and show you via a video clip.  Can you please share dwg?
Michael M. Carlson
CADD Manager
Message 5 of 16
CivilFlow
I realize it may be hard to package up all the data.  I would first check your Pipe Sart and Pipe End for that pipe segment.  Make sure the Pipe Start is at the start of your stationing for the profile view and the Pipe END should be connected to your structure.
If it is already like that, then you may have to add an expression to the Profile Band label style component to resolve it or just edit it to drop the negative sign.
Michael M. Carlson
CADD Manager
Message 6 of 16
MMcCall402
There is an option in the pipe slope label to set the Sign values as 'sign always (+-)'.   Is this not working or is it showing the opposite sign you're expecting?
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 7 of 16
shashimanandhar1417
Hi Mike,
Thanks for your suggestion. I am not very familiar with usage of expressions. I have attached the file here. Could you have a look and if you could upload a video of it that would be great help for me and other seeking the same solutions as well.
Message 8 of 16
shashimanandhar1417
Yes I have to show opposite signs to the slope what I have now.
Message 9 of 16
MMcCall402
The slopes are based on the pipe's assigned flow direction. How about just changing the flow direction. The inverts will all remain just as they are.
Mark Mccall
CAD Mangler
Message 10 of 16
shashimanandhar1417
How do I change the flow direction of the pipenetwork already created.
Message 11 of 16
MMcCall402
You could also make an expression (this may be where Mike was going) to reverse the the pipe slope.  The pic below shows an expression that should do it.  It merely multiplies the pipe slope by -1, which would change its sign from - to +.  Once you make the expression (under the pipe labels section in toolspace) it will become an available pipe property to add to the label style.
Mark Mccall
CAD Mangler
Message 12 of 16
CivilFlow
Hi here is another option to consider in addition to the others mentioned above.  Please watch this short animated .gif:
I hope this helps.
Michael M. Carlson
CADD Manager
Message 13 of 16
shashimanandhar1417
Hi Mike, Thanks for the gif. But that is not what I wanted to show. I wanted to show the sign but with the reverse of the sign what is currently assigned.
Message 14 of 16
shashimanandhar1417
Hi MMcCall402,
Thanks for your advice. I think your option should work. But I could not figure out the process of doing it. Could you post a video of your solution using my previously posted attached DWG file.
Message 15 of 16
CivilFlow
Hi guys-
I thought the expression way would work too, but for some reason once I created a new expression (under Toolspace\Settings Tab\Pipe) as @MMcCall402 described, the expression isn't available when trying to assign it to the band label style....it only shows pipe properties.  Really strange and frustrating.
Michael M. Carlson
CADD Manager
Message 16 of 16
MMcCall402
Sorry, I'm not able to make a screencast while at work. (they frown upon it)
After watching Mike's video I realized that the slope information is being used in a profileview band. Bands can't use expressions, so that option is off the table.
Reversing the flow direction is an option. Select and piece of the pipe network in the plan. The ribbon will switch over to the network tools.  In the Modify section there is a pull section of more tools. One of those tools is Change Flow Direction. Select that tool and it will prompt you to select two structures to use for determining the flow direction of all the connected pipes between them. Select the southern most structure as the UPstream and the northern most as the Downstream.  Now the band will show the correct slope but not the + sign yet.  Edit that band style and for the pipe slope property set the Sign to 'sign always (+-)'.  That should do it.
Mark Mccall
CAD Mangler
