working in profile view on a network pipe, I have been trying to get the Structure numbers to count backwards, where 1 is at the end, so that my labels are counting from left to right (as seen in picture) I was just renaming them individually but there are a lot of manholes. This is what I am trying to do:
I have this,
But am trying to do this.
Solved by MMcCall402. Go to Solution.
I'm guessing if you set the pipe network flow from upstream to downstream change to down... to up..
then try renumber parts
Joe Bouza
in the label style there should be an option to hide the sign of negative values
Joe Bouza
In plan view select the structures in the order you wan them to be named/numbered. I the ribbon pull down the bottom of the Modify panel and select Rename. The window that opens will allow you to rename/number the structures based on the format of the naming you enter. There is a Counter component within the naming convention and a starting number to be used. Be sure to check the box next to 'Rename existing parts' under the conflict options so it will rename parts as needed to works its way through renaming all the selected parts.
