Announcements
Profile View - Hatch
F.Camargo
F.Camargo
Hi friends,
I'm struggle with a hatch fill area at the profile.
Cut Area is Fine!
I don't know How can I do to fix it. Anybody could help me please?
Thank in advance
Fabrício
Replies (10)
click on the picture, it is a button on the left for fill area.
F.Camargo
That button you mean. I've already do that, isnt' working.
Fabrício
Sinoj.Ravindran
As long as you have created two profiles, ground and design, it must compare and shown in fill area.
Is it possible to share cad file?
F.Camargo
Hi @Sinoj.Ravindran
Yes. I create two profiles (EG and FG). But at the profile only cut hatch work properly, when I click fill area button, nothing happening.
Sorry but I can't share the file, but I will try to do an other file as a example.
F.Camargo
@Sinoj.Ravindran
File Attached.
Fabrício
ACADuser
Go into settings from the Toolspace, right-click "Profile View", then click "Edit Feature Settings...".  Under "Default Values" set a style for the "Fill Area Shape Style".  The button for adding a fill hatch should then work.
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
F.Camargo
@ACADuser
I've already try to do that. But ins't working too.
But I've notice that ins't match the style to "Parent Value". I think it is a bug.
Fabricio
ACADuser
Looks like you are in the command settings.  Try editing the feature settings...
ACADuser
cwr-pae
Try setting the defaults under the root of the Profile View of the tree. As a work around, just create a 'cut ' and set the upper & lower boundaries and shape to show the fill. The cut and fill buttons are only for the styling presets, they have nothing to do with actual work represented.
F.Camargo
@ACADuser
Thank you!!! Now it is working perfect!!
@cwr-pae  Thanks
