Civil 3D Forum
Profile view bands
20 REPLIES 20
Message 1 of 21
kishore.gudepuciv
1211 Views, 20 Replies
Profile view bands
I have two alignments. One is existing(Red Color in attached screenshot) and other is proposed(Green color in attached screenshot). Existing alignment starts with chainage 0.000 where as proposed alignment starts with chainage 240000. I am in a situation that I need to create profile bands in relation to both alignments.
I need to generate stations and elevations at major stations for existing alignment for example at 0.000, 0.020, 0.040.....etc., and for proposed alignment I need to generate at perpendicular point from existing alignment to proposed alignment for example 240003.45, 240023.51, 240043.46, ........etc.,
I can able to generate at major stations but unable to generate at non major/minor/geometry points with different stations.
Please suggest,
Thanks in advance.
Kishore.G
20 REPLIES 20
Message 21 of 21
Hello @kishore.gudepuciv @Anonymous @Jeff_M
I have published the dynamo package.
it is called Civil-Prokon, I believe it to be self explanatory but if you get time to look at it and get stuck then please just let me know.
The nodes you want to use is on this screenshot (correct workflow)
What will be created if the Alignments are created and selected is labels showing the intersecting point, chainage of the New Alignment and Reference Alignment
Also if the reference circle is placed in the drawing and selected in Dynamo then it will place the Databand information as specified
Kind Regards
Marnus van Staden
N.DIP Civil Engineering | Senior Technical Specialist
Autodesk Trainer | Draughting Consultant
________________________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
Apex Solutions Youtube Channel
Rail Community
