I don't know if you someone already posted this question before, but here it is.
Is there a way to have the station labels starting at 0+00 to whatever end station and start again at 0+00 from structure to structure? I don't want, let say I have 350 linear feet of storm drain to have the station starting at 0+00 and end at 3+50 when there are structures between 0+00 and 3+50. Basically, I want to start at 0+00 to 1+50 and start again at 0+00.
Solved by user181. Go to Solution.
Select the alignment and on the ribbon select alignment properties. Then go to the Station Control tab and select the button with the green plus to add a station equation. Then pick the point on screen you want to start at 0+00 again and then change the Station Ahead to 0+00. Repeat everywhere you want to restart.
