Profile slope percentage colour
arpenteur
arpenteur
Hi everyone,
As you can see in the attachment, the slope color is light blue.  How can I edit the color, please?
Thank you...
Replies (7)
Select the text, rt-click and edit the label style. Either change the color under the layout tab to your preference or bylayer.
arpenteur
I need more info. I understand under Layout, I see lots of options and I can't figure out.  Also, I can't change the color with Bylayer.
See where it say color under the text subject. It should probably say cyan (color 4) in your drawing. Change the color there to whatever you need.
arpenteur
After right-clicking on the percentage, Edit Labels, do I need to choose anything special in here?
Image in attachment
The lines see the description where it says Grades slopes
arpenteur
There you go....
Thank you for your patience.  You were a great help!!!
Grover_Puma
if this helps to solve your problem, ACCEPT SOLUTION please, this will help others find immediate answers. Thank you
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
