Profile Projection label side
RobertEVs
Advisor Advisor
RobertEVs
I see there is no OOTB way to add side in a profile projection label unlike other labeling, a Manole for example where you can add offset and side. All I can get is a negative (left) or positive (right) in the source offset
MMcCall402
You could make separate text components for each direction an then use expressions(s) to turn them on and off based on the source offset value being > or < zero.
Below I made a L and R component. The R one overlays the L one and has a background mask.  An expression provides a text height for the R component as needed.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
RobertEVs
Thanks. I'll try that out for my needs
Joe-Bouza
Use a pipe network structure b styled accordingly then you can get a ton of data to label
Joe Bouza
pkomatlapalli
Hi @RobertEVs ,
Did the information provided by MMcCall402 and Joe-Bouza  help answer your question?
If it did, please consider clicking "Accept Solution". Doing so helps other community members quickly find answers to similar questions.
If you still need assistance, feel free to post an update. We'll be glad to help with any additional questions or next steps.
Pavan Kumar | Community Manager
