Profile output (Create Sheets)
When I create sheets my Profile looks different even I select it from the drawing or choose the same settings manually. It does not pick up crossing pipes labels as well.
Can you attach dwg file
Here you are.
cwr-pae
I think this has to do with default style and command settings in your template. In the setting tab of tool space, find pipe network, commands, CreateNetwork, Label New Parts and change all those setting to true to apply labels to pipe network parts upon creation in profile view and in plan view. When creating sheets there are settings for default styles under the view frame group commands as well as those under the various object styles (profile, profile view, alignments, etc.).
Thank you.
