Hi
I try add the label inn profile Layout Label Group , I would like to add Tangent Length, I made other all labels except Tangent Length.
VIP No. 2
Chainage 0+014.50
VIP Level H=1000.30m
Curve Length L=22.000m
Tangent Length B=0.275m Required
Radius R=220.000
Lead Gradient i1=4.000%
Trail Gradient i2=-6.000%
K=2.200m
Your early response will be highly appreciated.
Solved by MMcCall402. Go to Solution.
I don't see Tangent Length as an available option however there looks to be enough information to use in an expression to calculate the length.
Something like this should do it. (simple triangle solution using the start and pvi locations)
SQRT(SQR({PVI Station}-{Profile Curve Start Station})+SQR({PVI Elevation}-{Profile Curve Start Elevation}))
When editing profile labels, the label type is Lines. In the label style, add a component that uses either tangent horizontal length or tangent slope length.
Sir,
First of all thank you for the reply, I got the tangent length in profile layout label text, unfortunately the all values are getting different,
VIP No. 3
Chainage 0+060.00
VIP Level H=997.57m
Curve Length L=43.400m
Tangent Length B=0.336m Tangent Length =21.739 I got this value
Radius R=700.000
Lead Gradient i1=-6.000%
Trail Gradient i2=0.200%
K=7.000m
Thank you
Sir,
Thank you for the reply, my question is Profile Vertical Crest & Sag Label "Curve Tangent Length" I got the answer from Mr.Mark Mccall, but I have to clarify the Tangent length of which I get from C3D, and CAD File. because the value is coming some variation from the CAD and Civil3D.
As per you reply I got the answer horizontal tangent Length. Sir please check the value difference of Curve Tangent Length, Red text is created from CAD, Blue value from Civil3D.
Regards
Nizamuddin.A
Sir,
Regards
Nizamuddin.A
Quite frankly you may not know much about what you speak! What are you trying to accomplish? Is this some kind of a miniature road?
You are asking about tangents, normally a vertical curve has a tangent coming in the the P.I. and a tangent leaving the P.I. Now it appears that you are speaking of the tangent portion between vertical curves.
What are you looking for?
Bill
Sir,
I got answer from Mr.Mark McCall, and I accepted, I look that one only, But I just ask the Curve tangent length different value of AutoCAD Curve No.6 (Red Colour) and Civil 3D curve No.6 Curve Tangent length (Magenta & Blue ) .
I just ask that value difference is same curve value in CAD & C3D.
AutoCAD value B=0.073
Civil 3D Value 20.978
Regards
Nizamuddin.A
I'm not so sure, but i think:
"AutoCAD value B=0.073 " this is tangent horizonal length (line between curve).
"Civil 3D Value 20.978" this is curve tangent length (tangent to PI)
