Civil 3D Forum
Profile Hatch does not work on companies template
5 REPLIES 5
wilsonm2000
467 Views, 5 Replies
Hi guys
I have tried to do a profile hatch on one of my models, using the normal method, going to the "Hatch Tab" in "Profile View Propseries".  But when I click on the "Cut Area" or "Fill Area" buttons on the left, nothing appears under "Hatch Area".  It seems to be the template we use, as when I use the Stock Template, it works fine.  I have looked for an option everywhere to turn the option on/off, but cannot find anything.  Any ideas?
5 REPLIES 5
uploading a drawing might help so we can look into it.
My first search would be within the profile-view style and look in the last tab if the visualization of hatches are turned off or on and what layer is used to show the hatch and look in the layermanager if that layer is off or frozen.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Joe-Bouza
in reply to: wilsonm2000
Insert your drawing into a drawing created with the stock template. if it works you'll know where to adjust your template
Joe Bouza
wilsonm2000
Nothing to do with layers. When I click the buttons nothing is added at all on the right to choose my surfaces.
Not sure how that helps Joe? I already know something is activated in the stock template that isn't in our template. I need to know what that is.
I realize this is 4 years too late, but I was having the same problem as well, but just figured it out.  Go into toolspace, settings tab, right-click Profile View, Edit Feature Settings, Default Styles, under "Cut area Shape Style" and "Fill Area Shape Style", the Value will be blank.  Set the Value to any style, and when you go back into your profile properties hatch tab, a box will pop up when you click cut area or fill area.
luis.chavezgamez
Nice job
Rail Community
