Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Civil 3D Forum
Profile disappears in PDF
6 REPLIES 6
petrocat
827 Views, 6 Replies
Has anyone noticed their profiles disappearing when using the DWG to PDF plotter with it set to "lines merge"?
We've noticed it on several sheets since moving from 2018 file to 2019.  When the plot settings are "Overwrite" the profile shows up. Didn't notice it in a DWF or going straight to printer.
6 REPLIES 6
Mike_Hurtado
in reply to: petrocat
Hi @petrocat,
Does it look ok when using print preview? What you see during print preview from Civil 3D is what is being sent to the printer driver so if the PDFs are missing anything this points to an issue with the plotter driver. What happens if you use one of the other PDF drivers?
Please Click the Accept as solution button if my post answers your question or solves your issue. Please reply with additional information if you're still running into the issue.
Michael Hurtado
Designated Support Specialist
Mike_Hurtado
Hi @petrocat,
Wanted to check in to see if you had any updates or if you were able to figure out what was wrong.
Michael Hurtado
petrocat
in reply to: Mike_Hurtado
Thanks for the idea. But, print preview looks fine. Still prints with the profile  at the PVI disappearing. This is using the DWG To PDF.pc3 with lines merge.
Tried a different PDF printer. The profile is there. When making a DWF, profile is there. When printing to printer, profile it there.
I still need to see if it is because we are using a file that started in 2018.
Mike_Hurtado
Do you have another workstation that you can test this out with? If you don't see the behavior on a different workstation, what happens if you copy the DWG to PDF.pc3 from that machine to your machine?
Michael Hurtado
petrocat
Actually, it was first noticed it on other computers first, then it came to me. I'm the designated trouble shooter in our office for AutoCAD.  We all point to the same pc3.  I will try pulling from a fresh deployment to see if that doesn't solve it.
Mike_Hurtado
Makes sense then why everyone is having the same problem. Let me know how pulling a new PC3 works out for you @petrocat.
Michael Hurtado
Rail Community
